telcoman wrote:Did you test your battery?
You don't mention whether the engine is cranking but not starting or not cranking at all
If its cranking but not starting check for spark
Then check for fuel
Follow the troubleshooting steps in the FSM
Good luck
Telcoman
How did you test your battery?melonz wrote:The engine isn't cranking at all. When I push the start button, it goes to ON mode and that's it.
Battery tested fine as well.
Any other ideas?
