RRISHHH300ZX wrote:hey guys, I drive a 1990 Nissan 300zx n/a. car has never given me any issues until last night. went to start it after leaving work and it had battery and sounded like it wanted to turn over but to me ( a non- mechanic ) it sounds like my engine wasn't getting any fuel. I checked my fuses thinking it was just a electrical problem but nothing was popped, tried even popping the clutch and get it started on a roll and nothing either. So I called a really educated friend and he said that he is 100% positive that its my COOLANT TEMPATURE SENSOR! please leave me some feedback on ways I can fix this! like I said its been flawless till now! only has 100,000k miles. AND BEFORE I GET A DUMB RESPONSE YES THERES FUEL!
Definitely check for codes. From my experience a bad coolant sensor doesnt prevent the car from starting it just make it run really bad. One thing to check would be your PTU ( power transistor unit) when these go bad the car will not start but you are able to crank it. Also double check your connection for the CAS (crank angle sensor) an issue with this one will also prevent your car from starting.
If you go the fuel issue route. Check the fuel pump relay. Do you hear the fuel pump turn on when the key is in the ON position?
