monching »
https://forums.nicoclub.com/monching-u183865.html
Thu May 05, 2011 7:50 am
car will starts in the morning when it's cold and then not again until it cools off. When you turn the switch it will only click (sometimes 2 to 3 clicks) to relay that is mounted on the fender wall, but it will not engage the started. The battery is fully charged and we have replaced the starter with another used one. Car runs fine after it starts and it will run until you cut it off. It is a manual shift transmission and you can kick start it when it does not start. do we need to replace the relay mounted on the fender wall? Any help is extremely appreciated for 1992 nissan 240sx
