If the engine is very hard to start because it is flooded, depress the accelerator pedal all the way to the floor and hold it.
Crank the engine for 5 - 6 seconds.
After cranking the engine, release the accelerator pedal.
Crank the engine with your foot off the accelerator pedal by turning the ignition switch to START.
Release the ignition switch when the engine starts.
If the engine starts, but fails to run, repeat the above procedure.
CAUTION
Do not operate the starter for more than 15 seconds at a time. If the engine does not start, turn the ignition switch
off and wait 10 seconds before cranking again, otherwise the starter could be damaged.
philipa_240sx wrote:If the engine cranks, but will not start. Try the flooded engine procedure from pg 5-11 of your owners manual:
CAUTION
Yes. If the engine does not start on the first or second attempt, it will flood the cylinders with fuel making it impossible to start.AznJohn22 wrote:How did I flood the engine? With gasoline?
casperfun wrote:Stop busting your balls and torturing yourself. Use the 36month/36,000 warranty coverage!
casperfun wrote:Yah, it came when you purchased your vehicle. If your car won't start, the dealership will fix it for free. Drop it off, get a free rental. Bada-bing Bada Boom. Problem solved.
At least that is what I would do.
I'll kepe it in mind next time. Thanks for the info.casperfun wrote:I get free towing from triple A but you could get the dealer to arrange something since its under warranty.
