Car wont start
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
dvil5
Car: 2007 Nissa Versa
I have my 07 versa s I left my custom fog lights on and caused the battery to die out. When I tried jump starting my versa it just wont start. I tried everything from changing the gas pump to checking the ignition coils. My coils dont send any sparks but they do recieve energy. I think is my cam shaft does anyone has an answer for this please let me know I dont know why it wont start. thanks
steed77
Car: 09 Versa Fresh Powder Sedan 6speed
Sometimes when you discharge the the battery that far, it will not come back.
Past experience tells me to replace the battery... or ... at the very least... remove it and have it tested.
You may have a dead cell and it can short out and while that is still inline, it will not let anything work.
dvil5
I took the battery to get checked and they said it was good. I ran the diagnose machine and 2 codes came out the hi temp fuel and bad gauge reading for the fuel also.
steed77
Check you fuses... might be a fuel pump or ecu fuse
Return to “Versa Technical Discussions”
