this is your issue..the rotor should be pointing at 20 degrees before top dead center...not at tdc...redo the timing man and the issue should go away..anjoy and post back with the results.Kakid240 wrote:yeah the car does sputter when i am cranking it and the rotor is pointing to the number 1 spark plug wire at tdc on the compression stroke should i redo it??
It would be 0 at TDC (engine off) and 20 degrees at idle for the DE engine, 15 for the E. Sounds like your timing is correct.liquid_cool wrote:
SureKakid240 wrote:this happened all of a sudden do you want me to take a pic of the rotor at tdc so you can confirm it is right??
