Car wont start
Geronimo77
Car: 1990 Nissan 300zx Twin Turbo
I have a 1990 300zx TT and it started driving pretty terribly....it was sputtering and had a hard time idling, eventually it stopped running altogether...I figured it was the spark plugs since i knew they were old...bought new ones..put them in and i still get the same thing....wont start
http://www.youtube.com/watch?v=3V-Fen87eSE
NolimitZ32
Make sure you got fuel pressure maybe its the camera but it sounds to me like its got no resistance when you crank it makes me think no fuel in the chambers.
Geronimo77
Im getting fuel to the cylinder, i tested the plug outside of the cylinder and im not getting any spark...im pretty sure its not my coil packs cause i don't think all 6 would fail on me at the same time...definitely electrical, but i dont know past that
Geronimo77
Im getting a spark to my plugs now, and im getting fuelI think that it might be a timing problemStill making the same noise and everything...no start
Geronimo77
Just did a compression test.......0 compression on all cylinders,i see the pistons moving but no pressureany ideas?
StrayCat
Car: 2006 M45, 1991 300ZX TT
First step should be to pull the codes from the ECU. Do a search for the procedure and the codes. I'd bet that you're getting a code 13, faulty coolant sensor. You can also pull the coolant sensor plug on the front pipe, and clean the contacts well and try it again. Common issue.
Geronimo77
Started pulling apart and found thishttp://www.youtube.com/watch?v=PT_BqAa4paE
bentandbuzzin
Car: 1992 300zx n/a manual 2+0
Looks like your belt tensioner is shot or you broke your timing belt. From your first video it sounded like only the crank shaft is spinning. There should be some drag on the engine when you crank it. You found your problem. Lift up on the belt to see if its comes out if its broke or pull your crank pulley off to remove that lower cover and you will be able to see what happened.
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Yikes!! How many miles on the engine? When was the last 60/120K maintenance done.
Pieceofsand
Car: 91 300zx Twin Turbo
dirty looking lol.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
If the crank was rotating separate of the camshafts, you might have hit a valve with a piston and damaged it in some way.... Definitely want to look to replace the belt and most likely the tensioner. Just hope you didn't strike a valve with the piston...
Geronimo77
I was actually like a a week away from doing my 120k im at 118,000 right now.....i guess 60k never got done, thanks previous ownerAs for bent valves im pretty positive some of them got damagedso this is happening...
Ace2cool
Ouch, man. Kudos to you for not giving up on it though!
Geronimo77
haha Thanks,Pulled injectors, valve covers, and 2 cams today
NissanFairladyZ32
Car: 91, Twin Turbo, 99 Miata 1.8L
Sorry to see that belt broke man
i feel you're pain
ps we have the same plates Turbo Z
Geronimo77
haha awesome,Such a good plate....as soon as i bought my car i was like i need this plateand thanks, its coming along
jesssam28
so how much is rebuilding your head or valvetraing going to endupcosting you,,,???? loooks really good from the pics; it just makes me wantto do the same to my engine..lol...keep up the good work
Geronimo77
Im not to sure to be honest i know what parts cost but not certain labor and other unaccounted stuffIm planning on doing:R5 cams-$1000ARP head bolts/studs-$200Cometic gaskets-$150EGR delete-$35Ferrea full valve/dual spring kit- $1500Tomei Solid Lifters-$500Plus ill prob get a shop to install some head parts for me and make sure the head surfaces are alrightAt least thats the plan for now
jesssam28
dude...that sound like a lot of bling......but you'll be enjoying every single second after you get it all done....
i'm looking forward to all of that, but more towards the end of next year
