Postby
Warlord22 »
https://forums.nicoclub.com/warlord22-u105202.htmlFri Oct 24, 2008 4:57 pm
So heres the situation yesterday while trying to fix the third coolent leak this week while i was tighting the coolent bleeder screwf ro some reason the jackass before me had riped so of the electrical tape of on the injector plug so when i was tighting the screw it touched and made a spark which i hurry up and stop what i was doing anyway went to start car and it cranks juat wont turn over I need Help or any info thanks
Postby
le_ryan »
https://forums.nicoclub.com/le-ryan-u30337.htmlSat Oct 25, 2008 6:47 am
chances are, you shorted out the injectors, poping a fuse, like he said, check your fuses, if they are all good, then check to see if your getting fuel from the injectors.if you are getting fuel, then check that your getting spark.
Postby
Warlord22 »
https://forums.nicoclub.com/warlord22-u105202.htmlSat Oct 25, 2008 9:36 am
so here is the update checked all fuses and found one that is bad the one in the driver side that says st signal so i replace fuse and nothing so then i checked where the fuse goes into and there is no power coming out so what do i do now
Postby
stephen240 »
https://forums.nicoclub.com/stephen240-u96805.htmlMon Oct 27, 2008 8:53 pm
1) Could be distributer problems.2) Could be fuel delivery problem. (Check fuel regulator, mine leaks so takes a second to start up)3) Starter could be weak.
Before i get bashed I am just stating things I know about to try and help....
