Car wont start!
Salvadorian561
Car: 96 240sx se
Ok I bought a 96 240sx se today the engine was dirty so I bought engine bite to clean it and sprayed it.. when I went to start it up in was on for like 3minutes and out of no where it shut off. Tried starting again gave it gas but no start? Any ideas? Need Help soon I juss got this car
Goldeneagle
Car: 1992 240sx Coupe
It is hard to say or have any clue as to what may be going on with so little information.
When you try to start the car, what happens?
Salvadorian561
Car: 96 240sx se
It cranks but no start. I tried pushing the car and starting but no luck
mb_s13
Car: 91 Nissan 240sx
You could start by checking your fuses, you might of blown one.
Black on Gold
Hope you didnt get any water on your wiring or any other electrical part
nismoboy92
Car: 1992 240sx coupe
happend to me.blew my fuse for the fuel pump.gl man try all your fuses b4 you get to worried
Salvadorian561
Car: 96 240sx se
We checked fuses and some guy told me its the Distributor
carkook
Check for spark, and fuel. Is ther spark coming from the coil? I recently had the same problem and it was because the distibrutor drive gear snapped, to check this just take your dist. cap off and make sure it doesnt spin freely.
Salvadorian561
Car: 96 240sx se
No there aint but tomorrow im replacing it. Also speedometer doesnt work my rpms go up and down. Could it be a fuse or something?
carkook
I would check to see if your getting power to your ignition coil, and then if theres spark coming from the ignition coil.
Salvadorian561
Car: 96 240sx se
Ok thanks
