Car Wont Start
mias13
Car: 1991 Nissan 240sx
ok im having trouble with the car.its wont start, we checked spark OK, Fuel OK, External coil OK, Plugs OK, Distributor OK. i have no clue what it could be. please help
EnjoiNismo
Car: 93 240sx
is there any noise at all when you try to start it?
scrats240sx
Car: Nissan 240sx
I was going through the same thing until my fiance took the valve cover of and opened the timing chain cover. We had no idea that the timing chain had granaded and chewed some of the gears. I was getting on the interstate going to work and the motor just shut off. Unfortunatly once he found this out I now have to sit and look at my baby in the driveway. Maybe this will help you in trying to figure out what is wrong. I wish that I could get mine back up and running but with limited access to parts in my area she will sit until we can come up with something. Good luck with your car.
xrider252
Car: 98 kouki
does it turn over????,i would do a compression test to see if the engine good then go from there. if u dont knwo how to do one lmk
ka-t4u
are the injectors sending any fluid, is it cranking over? if it is do any of the cylinders fire at all??
