car wont start :(
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
ok check it out...when the key is in the on position (right before the one to turn over the engine) i can turn on basically 1 acessory at a time...if i turn on the radio, and then turn the ac on...the radio will go off...when i turn the car over, all acessories flicker as well as dash lights, and the car makes a weird clicking noise, it's really rapid w/ no acessories on but only 1ce w/ all acessories...what is goin on here?
96_S14_SE
Car: 96 S14 SE - 05 VW GTI 1.8t - 89 S13 coupe "gold on brown"
Is the battery good, and all the contacts clean and on tight?
Silly question but I gotta ask.
MainEvent212
yeah of course, the acessories/lights etc...they all turn on, but it seems like the power goes down when i turn on multiple acessories...like a/c works fine...but when i turn on the radio the air slows down and the radio flickers then cuts off...
Holisticbeatz
Check the starter motor maybe?
Perhaps this thread should've been posted in the Nissan Online Mechanic forum where NISTECH moderates.
yellow_jacket
Car: 95 240sx
Have you tried jump starting the car? It really sounds like a bad battery or a bad connection somewhere.
pervytheclown
Car: Cars (obviously..), Music, and "fly-*** *****es"
check your distributor too..My Altima acted funny like that once.
s13sr20chris
this is silly but i frequently see loose batt connections. they may also be broken.def sounds like a little voltage prob.
NISTECH
all your accesories on at once hardly draw any ampreage your starter draws at least 100 amps. you have a dead battery!
