car wont start...
corey240
Car: 1993 Nissan 240SX Base Drift Machine
went and got the solenoid replaced ony my starter and it was fixed and now the car will not start but a few times randomly. i turn the key and trhe car clicks like a dead battery...even in jump start...then it wil click and my tach needle just starts going wild and it wont start. what the ef can this be?
corey240
anyone?
srdrps13
Car: s13
is the car getting sparks? i recently tried to start up my car after a few months and found there to be no spark... need to get back out and check it again... good luck
corey240
FIXED!!! my uncle came over today and was like so did you fix your battery ground? i said yea and the car still wont start. so he says what about your motor ground? i said i dont know. so he is like hey you have jumper cables? i gotem out and he hooks 1 end to the bell housig. then hooks the other down by my intercooler pipe on the body. says try it now. and BOOM! it starts right up. hooked up a ground wire from my intake manifold plate to the wheel well and fixed! so any of you thinking your starter is out it may be your grounds somwhere because it is a very easy thing to not check out.
