Car wont start... Something draining battery?
Idunno..
My 240 has been sitting in storage for the last 2-3 weeks, today i went down to start it up and take it for a ride since the snow is melting etc. And it wont start. My father seems to think something is draining the battery but were not too sure? Why would the battery just not start? its brand new, got it a month ago tops, and has barely been used. Im sure it wont be any trouble to get it going besides a boost, my only concern is this happening to me when im out and being stranded. Any suggestions to what the problem could be if there really is one to be concerned about? thanks.
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
charge you battery, then, use a test light, disconnect negative cable off battery and use the test light to complete ground. if you have a drain while the car is off, the light will light up. if that happens, pull fuses until you have determined with circuit it is, then back track from there.
Idunno..
Whats a test light? where do i get one?
EW
Car: 95 S14
98 Cobra
06 F150 supercrew
Modern cars ie cars with computers in them, radios with presets, clock, etc CAN NOT SIT FOR LONG PERIODS OF TIME WITHOUT THE BATTERY GOING DEAD! You must use a Battery Tender Plus or similar item to constantly charge/monitor the battery. Once the battery is dead (below 10.5V) it will never, ever come back to full strength AND if you try to jump start the car and then charge a dead battery with the alternator, you may expect to purchase a new alternator soon. If you want to park a car and not use a charger 24/7, then unhook the battery. Batteries are not magic and ALL batteries will run dead when connected to the car and not used on a regular basis.
Idunno..
Ahhhh alright, that last explanation helped clear things up, thanks alot to both of you.
FeintMind
Car: 2005 Nissan 350Z Base
check your starter too...
for a while there my starter would just not want to work, and so id have to bust out the trusty lug wrench and whack the side of the starter a couple times and then it would start... havent had that issue in quite a while though...just a thought. but yeah if its been sitting for a while and now wont start, and you have determined the starter isnt the problem, then you most likely have some parasitic loss going on, open circuits, whatever else. bad grounds maybe?
Idunno..
Im pretty sure its not that starter. My audio system turns on when the car is off, and it didnt turn on. So its definitly the battrey. Not only that but a few days before i went to check it and it didnt work, i turned it on just fine, about 4-5 days before it didnt work. So i doubt its the starter.
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
Its always a smart idea to disconnect negative cable from battery when you are going to store your car for a long period of time.
White Comet
Car: fc, s13 and mazda6, Sierra
EW is 100% right thats what i was coming in here to say
BMAR240SX
Car: 1993 Nissan 240S Coupe
I keep having the same problem with my 240, so i just got a new battery and i disconnected it and left it in storage. Going to possibly turn it on during spring
jinjinweiwei
Car: 95 240SX
EW wrote:Modern cars ie cars with computers in them, radios with presets, clock, etc CAN NOT SIT FOR LONG PERIODS OF TIME WITHOUT THE BATTERY GOING DEAD! You must use a Battery Tender Plus or similar item to constantly charge/monitor the battery. Once the battery is dead (below 10.5V) it will never, ever come back to full strength AND if you try to jump start the car and then charge a dead battery with the alternator, you may expect to purchase a new alternator soon. If you want to park a car and not use a charger 24/7, then unhook the battery. Batteries are not magic and ALL batteries will run dead when connected to the car and not used on a regular basis.
...dude my zenki have the same wheels with the zenki on ur sig...
Idunno..
Quick question, my father seems to always think the worst, but he thinks something is wrong with the alternator or something bla bla bla. So just real quick can the battery naturally with a drain get drained in as little as 5-7 days. Or just it usually take more then a week?
yoshi_hito
get a voltage meter.. comes in handy and it will be a good arsenal in your tool box vs the wiring gremlins! Also u can take batter yup to auto zone and a few other places and they will check your battery for free to see if its messed up
White Comet
it depends on the battery if its a weaker one it might drain in less than a week, i have an optima red top and it woudl never drain that fast
