car wont start,need help quick. possible air in fuel lines
nothingFancy
Car: r34
i got a 97 240, i took out the ka to replace it with the sr but i sold the sr and put the ka back in. reason y i did that is because i thought the swap comes with everything but i was missing parts so im gonna buy the clip. but anyway, all connections are connected. it cranks, it ran for a min then it shut off,2nd time i turned it on it ran but stumbled and when i gave it gas it choked and then it died. now it wont run no more. im thinkin theres air in the fuel lines,
how can i bleed the fuel lines?
thanxDan
navysnail
there is no air in the fuel lines, it would push out when you started the car, but it does sound like maby the pump fuse blew, check that
240convert
sounds like we're on the same page...sorry i'm not going to be any help but good luck
nothingFancy
Car: r34
all it needed was gas, i could of swore there was a tad bit left before i pulled it out
