kmckis1029 wrote:well ill take it!!!!!
One thing I am looking at is getting a LCD oscilloscope, they have come down to where they are almost affordable. I have several older ones that will work, just a little inconvenient.
I am not a fan of these kits largely because I see many design errors in most. One thing to avoid is running a ground that may have circular currents next to a any cable that provides a signal as it may introduce noise into that cable.
Here is an example of one you can hear. You connect up an old 12 AM radio and you have ignition noise. Now you figure well I can provide the 12 plus lead using a coax cable with the outside grounded on both ends since the source of noise is usually the power lead to the radio. Since these addons typically run through the engine compartment you now have picked up all this electrical noise and introduced it to the power lead. Now disconnect one end of the shield on the coax and the issue goes away.
Introduction of noise into an AM radio disrupting your listening pleasure is a whole lot different then introducting noise into a system that controls how the car functions.
To me if you want to 'smooth' out your power flow, I would use the electrical devices that are designed for that purpose. The problem here is that this could be hazardous to your cars health if there are systems designed to instantly shut off when the vehicle is shut down especially without the use of blocking diodes on every connection to the device/module.
This doesn't mean that if you think you have a grounding issue that you should not check this out and fix it. I have seen issues before due to repairs on the car where grounds were compromised. If found replace them with the appropriate size, although often all that is necessary is to clean up the connections. If it is a chassis issue then locate where the ground fails and add as short of jumper ground wire as possible to fix the issue (bonding). For example I have seen headlight issues where the ground was disrupted to the headlight housings.
Perry
