car wont start !!! HELP !!
natguerrero
Car: 240sx sr20det
alright im on the way home on the highway and the car just dies !!! no power , i luckily make it to the side of the highway and i pop hood and check it all out nothing looks bad try to crank it and nothing ! get it home on flat bed !
well now i think its the alternator had it tested and it was still good ! put it back in with new battery and nothin ! car doesnt start at all ! the only power i get is to the lights and electric fan ...the alarm , gauge cluster, dont come on
so what do i do ??what could it be !!!! ????
tiger
duuude, go to the fusebox by the battery and check that big gray fuse.. betcha it's blown!!!!!!!!
S13FASTBACKSR
Car: '92 Fastback SR powered
car is not cranking at all? check the fuse and then do a compression test
S14-KOUKI-MONSTER
Car: '97.5 Kouki s14 le w/Kouki s14 sr & '03 Xterra w/6" lift on 33s
I have a very similar issue as of yesterday. Went into the store to buy smokes, came out and tried to start. Cranked over really slow, and the second time I tried to start it, there was nothing. Didn't even hear the starter solenoid click, or my fuel pump turn on. Assumed it was my battery/alt, but when I tried to jump it with my xterra, nothing at all. Checked the battery with a multi-meter, and it reads a full 12.6v??? Gonna try to figure it out this evening, time permitting.
drftsx
Car: 90 240sx(sr)
im pretty sure its the alt fuse is blown. Check that out. Good luck
driftneil
Car: A pile of cars.
S14-KOUKI-MONSTER wrote:I have a very similar issue as of yesterday. Went into the store to buy smokes, came out and tried to start. Cranked over really slow, and the second time I tried to start it, there was nothing. Didn't even hear the starter solenoid click, or my fuel pump turn on. Assumed it was my battery/alt, but when I tried to jump it with my xterra, nothing at all. Checked the battery with a multi-meter, and it reads a full 12.6v??? Gonna try to figure it out this evening, time permitting.
Did you figure out your problem?
s13_maJiK
Car: s13
When you crank it do the headlights dim at all?
