Rossco16 »
https://forums.nicoclub.com/rossco16-u213151.html
Fri Jul 19, 2013 11:57 am
So I removed the CAS and turned it while the key was in the on position, and I didn't hear any injector sound or anything, then I decided to check the connector on the CAS to makes sure it was getting power, I turned the car on while I checked the connector and got some light on 1 of the 4 connectors(using just a power tester), so I assume the CAS is getting power but just isn't working so my injectors are not firing, the battery at the time wasn't fully charged so today I charged up the battery and im going to try this again to see if I get any sounds while turning the CAS. At this point I think I've found the problem, I've already replaced the PTU because it was the recalled one. If anyone can think of another possible problem please post and let me know, I was also thinking about checking my ECU to make sure something isn't messed up there, I've checked the fuses and some relays, if anyone could let me know of there exact location I could check them again to makes sure its not just simply a fuse problem.
Is it possible to check the injectors with a simple power tester? or would I need to break down and get an ohm tester(I eventually will but im not rich at the moment), if so what would be the best way of doing so?
