car wont start after changing a injector
mofeel
Car: red 1990 Nissan 300zx n/a 2+2 5spd. sold
1993 nissan 240sx fastback 5spd. sold
2000 gc8 Impreza 2.5rs coupe. daily
1974 260z. project
jus recently i changed an injector and bypassed the tb coolant lines n the car is trying to turn off but sounds like the starter is out but its turning over. sumone said a starter gear or a flywheel problem. any advice?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
so you turn the key, does the engine spin? do you hear the starter click? do you hear the starter turn?
mofeel
1974 260z. project
i meant to say trying to start. it turns over but when it actually turns over its makes the sound a starter makes when it goes out. could it be the harness for injectors n coils? cuz they r kinda corroded looken.
mofeel
1974 260z. project
the motor also shakes when it does it too.
evildky
06 Nissan 350Z GT
when the starter goes out it clicks or makes no sound...
so the engine is turning right? this means your starter is fine but you are lacking spark or fuel
NORCAL300ZX916
Car: 91' 300ZX 2+2
is it turning really slow/ slowing down before kicking over? your battery terminals not being tight enough or corroded will cause the starter solenoid to drag on its way in and out. how old is the battery also?
mofeel
1974 260z. project
idk how old the battery is. but the car is turning over jus dying as soon as it starts pretty much. thinkn maybe the harness for coils n injectors maybe. idk tho its got me stumped. it didnt do this til i put the injector in.
evildky
06 Nissan 350Z GT
so the car starts, then dies? defineitely not a battery or starter issue, most likely a spark or fuel issue
check the ecu for codes
NORCAL300ZX916
Car: 91' 300ZX 2+2
is there gas in it lol?
mofeel
1974 260z. project
yea its got a 1/4 tank aiight slingblade lol
mofeel
1974 260z. project
i checked ecu n it brought up code 42 for temp sensor circuit
evildky
06 Nissan 350Z GT
clean your connections and reconnect them, the old corroded connectors have a tendancy to loose connectivity when fiddeled with
mofeel
1974 260z. project
after 11 weeks of the car not starting it finally started today after a new ecu n sum ether, a few plugs need plugged in colors not matching and looking for a diagram. thinking maybe a fuel filter cuz the pump is kicking on.
evildky
06 Nissan 350Z GT
are you getting fuel at the fuel rail?
mofeel
1974 260z. project
its running now.it had a miss on the 3rd n 6th cylinder changed the plugs n its good. jus need a tail light amp i think cuz my brake lights aint working. but my emergency flashers r working. n also i have loss of power steering while turning sumtimes. so ima check the pressure hose n c if thats causen it.
mofeel
1974 260z. project
actually the plugs didnt help n need sum advice on wat it could b. tempted to sell it.
