Car wont shut off lights wont shut off wtf
DanDrath
Car: 1990 Nissan 300ZX 2+2 TT
So i turn my key to turn the car off doesn't do anything car stays on and all my dash lights stay on. If i stall the car all the dash lights still stay on. Now i have to disconnect my battery so my car doesn't die every time i turn it off. What can this be?? I am seriously so confused. I was thinking ignition or a relay but someone give me some ideas please. t.y
DanDrath
bump please. I know there are some electric experts on here.
tmeyer29
Car: 1990 300zx TT , 04 Yamaha R6
Sounds like a electrical problem.....ha, I would suspect the ignition for sure. maybe it has a short. Try taking the cover off the column and wiggle some of the wires going to the ignition and see if anything changes.
DanDrath
^ lmao thanks for that one. Idk how i can check the ignition to see if its bad. Thats what i think too though
DanDrath
tryed wiggling the wires didnt do anything =[
tmeyer29
maybe bad starter switch..but that wouldn't explain the dash lights still on. i dont think?
tmeyer29
my mind is trying to work. check and see if you can turn the ignition on with a screwdriver(obviously dont crank on it hard). If it turns easy then something is probably binded up in the ignition. ps i have one more post than you
DanDrath
what do u meen like stick a screw driver in the ignition? idk what would be stuck in there. Now we have the same amount =p
tmeyer29
try to use a flathead as it were the key. Just put it in there a little ways and see if it turns easy. dont force it! hmm maybe this doesnt make sense, what im saying lol. I would think even if something was bound up in the ignition that the contact points would still change when you turn the key.
tmeyer29
do you have remote start by any chance?
DanDrath
no remote start, my ignition lets me pull the key out even if the ignition is in the on or started positions. It probably will start with a screw driver
tmeyer29
im sure. mine used to fall out around corners to the left lol. one time it fell out and I couldnt find it. looked like a idiot cause i couldnt turn the car off. were you always able to pull key out on the on pos. or just since this problem? at any rate, get yourself a new ignition ASAP. dont want the z stolen.
DanDrath
I was always able to pull it out. My car always has this issue when it rained then the next day it was fine, but now its completely dead the ignition only starts the car and when i try and turn it off nothing happens If i get a new ignition wont i need a new key too?
tmeyer29
it will come with a key. but you should be able to bring it to a locksmith and they can re-key the tumbler so it matches your current key.
DanDrath
yeah i wanna do that cuz i <3 my titanium key. I am ordering a front clip soon so i can probably just use that ignition instead of buying a new one
