car wont run
mcmiles16
Car: 1991 nissan 240sx
i have a nissan 240 the eng cont fuse keeps blowing and when i try to crank the car the fuel pump does not come on
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Welcome to NICO. First lesson, be careful if your doing a poll about not having open options as you can see above. Hopefully someone has an idea about this and can help you out.
mcmiles16
can you help me get an idea on whats going on
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
Best I can do for you right now is point you to the FSM.http://www.nicoclub.com/FSM Your answer will be in there, or possibly someone else will come along with an answer. Did you do anything to the car before this happened? What kind of mods have you done to it in general? There's a lot more info that you need to put in, like what year it is even.
mcmiles16
it is a 1991 i am geting the car ready for a swap i have takeing all the heating and cooling stuff out to lighten the car and the firewall insatllion
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
That circuit only goes to the ECU and the bulb check relay. It's either a bad computer or a grounded wire somewhere, which is probably more likely considering you've been taking stuff out.
