I have an s13 with a ka-t. It wont stay running. It was running fine until i replaced the turbo. The day i parked it, it ran fine. Then it sat for two weeks while the new turbo came in and whatnot. I put the new turbonetics t3/t04e on (same thing as i had before, only brand new) and go to start it... now it runs like piss. The best way to show u what its doing is with a video...
http://www.youtube.com/watch?v=7Ndmu-qw38U
Here is the list of things that i have replaced/checked so far
No clogs in the IC piping
MAF is good
o2 is good
Temp sensor is good
Resistance across injectors are good
No blown fuses
Car has good vacuum
Fuel pressure test, 10psi while primed and not running, 41psi when it fires up
Replaced the fuel pump with a new walbro 255 anyway
Replaced fuel filter
Cap and Rotor is good
Spark plugs look ideal
Coil pack is good
Its been a 3 weeks since it was last running and im totally stumped.
