heggytime wrote:ok so cleaned all stuff with air compressor and dried em out with qtips everything looks good maf looks good so i went and got a obd2 scanner and it says plug up under dashboard but i cant find the dcl or whatever its called to plug it into...i searched around and saw some stuff talking about the year of the car matters wich obd u get...do i need to get a obd1 or some something...i read the link on retreiving codes in the ulta sticky but it said engine needs to be on and thats not an option...as i said before very novice mechanic and need help asap...thx
the car just has to be on, the engine doesnt have to be running. just has to have codes stored in it, so make sure youve ran it since any battery disconnections.
your car is not obd2, so that code reader will not work.
