C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Mon Oct 03, 2005 12:02 pm
I'm going to post here rather than your new thread. It makes it a lot easier to follow so we know what has been discussed already.
I think craviong boost was telling you to hook up a compressor directly to the wastegate signal port. Use a pressure regulator and starting at a couple psi, slowly raise the pressure. You should see the wastegate open as you near the wastegate's set boost level.
Looking at your prior post about the gaskets, regardless of brand name, make sure they are graphite impregnated or a metal gasket(copper or multilayered steel). Nissan's OEM gasket is graphite impregnated with a perforated steel backing. This should be the minimum. And Nissan's gasket is also 4 pieces(DOHC KA motors).
I'd eliminate the exhaust leak first before exploring other areas. Troubleshooting any problem is a methodical approach of eliminating possibilities in a controlled manner. Leaving a leak in place may make it more difficult to find. Not to mention, gasket leaks will become bigger as they continue to leak. Usually, it eill result in blowing out a portion of the gasket. I've seen enough wastegate gaskets fail to know this first hand. Each one started when the wastegate started to become loose, and eventually ended up with much of the graphite in the area of the leak being completey blown out. These kinds of gaskets are only durable when they are leak free.
