Red coupe »
https://forums.nicoclub.com/red-coupe-u19771.html
Thu Oct 06, 2005 12:52 pm
So from the research I did I found 32 is the egr system. I saw Nistech's advise to check the small L hose going from the egrc-bpt valve to the egr valve. Its cracked at the bend and I can feel air coming out. Any one happen to know this part number?
Its been running fine, although I have had a code come and go(usually before I get a chance to check it) finally the code comes on, and every now and again (getting more frequent) it wont start, and when it does, it wont idle for the first 4-5 seconds. after that its ok, other then the fact that it idles high ~1.5k, replacing this pipe should clear that all up yes? is there a way for me to make it start reliably until the new hose gets here?
