Car wont crank sometimes
Holvinator
Car: 1995 Nissan 240sx SE
I Have an S14 with a redtop on it
Symptoms:
When turning the keys in the ignition to start up the car it wont start. You here a click sound on the starter but it wont even crank;lights on the dashboard doesnt go anywere (like if you have a bad batt.)
Things I have tried:
1-When I have the keys on the on position and the car doesnt start up, I leave the key on that position and I shake the keys up and down and in circles to c if there was a bad conection or something that is not doing contact inside the ignition switch.
2-I took my car to Advance Auto Parts and they checked 4 me the starter, batt, crack power, alternator, and other stuff and everything is normal including battery.
3- Not to long ago I had to re-wired my harness because (Carisma- Specialist on 240sx here in F.L) notice that (f@&0ts over @ Delirium Motorsports) direct-wired everything on my car.
*** I already replace the ignition switch and still having this issue ***
could it be maybe... the Turbo Timer?? I have installed for about 4 months. Any inout guys will be appreciate it. Thanks
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Its becoming more and more common. Two things to look at are the start signal relay (manual), or the ignition tumbler. Happened to me often, it was the tumbler, I cleaned the contacts and its been good since, voltage was dropping from 12.3 to 6.2 through the dirty contacts
martins_240sx
Car: 1990 240sx hatch, 1975 280z, 2005 F150 fx4
also remove your battery and look behind it. there is a relay there replace it from NISSAN not autozone or kragen. My car did this the entire time on the dyno. changed a few starters to no effect. went out to my coupe and swapped them out and started perfectly. went to nissan and got a new one. They told me it was one of there most replaced parts
costa_rican13
Car: 1993 s13 coupe
martins_240sx wrote:also remove your battery and look behind it. there is a relay there replace it from NISSAN not autozone or kragen. My car did this the entire time on the dyno. changed a few starters to no effect. went out to my coupe and swapped them out and started perfectly. went to nissan and got a new one. They told me it was one of there most replaced parts
name of the relay would help!!! im having a very similar issue!
martins_240sx
starter relay i believe...take the relay out and they can run the number thats on it.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
only MT trans cars have a starter relay
martins_240sx
sounds like its a manual transmission..like i said in another post...im 97% sure this is your problem
costa_rican13
Car: 1993 s13 coupe
OutToWinPAHC wrote:only MT trans cars have a starter relay
my car does have a MT
Holvinator
My friend that works on 240's (sucks he moved 3hrs away from me) told me the same thing. That it could be the starter relay. He told me that is mounted to the side under the car, under the fender in the engine bay lol. So what is it? buy a new relay will fix the problem?
My car was automatic tho. You think I have that relay after I did Sr20det (redtop) Swap? I have an S14.
Is there anyway you could get that relay part #?
costa_rican13
Car: 1993 s13 coupe
Wheres the starter relay?? All i can find is the ign switch. Maybe a pic please??
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Check out this
search.php?keywords=start%2C+relay%2C+i ... mit=Search
And check the FSM shows pics
hatedinthemind
Car: S13 Coupe, Subaru Forester
It might also be called an interlock relay?
martins_240sx
that is it/\...all your problems will be solved
Hijacker
Car: '92 240sx Convertible
'94 F-150
Don't forget to check your battery cable clamps. I've had the exact same symptoms in the past, and it was corrosion on both the terminal clamps.
Holvinator
Thanks alot guys 4 all the replies. I havent change that relay yet but Ima try something else before replacing that relay. Ima unplug the turbo timer and put everything the way it was before to see if it will stop the problem.If it will still w/ the same issue I know that is that relay. any idea how much would it cost? and if its hard to put it in?
hatedinthemind
You mean the relay? Its simple, just remove the battery and it will be inside the passenger fender. Mine wasnt even bolted to anything. Theres just two plugs that plug into it. They cost around $23 from a Nissan dealership. :bigthumb:
Holvinator
ight, going back to this old post. The problem was the actual signal cable that connects to the starter. What happened was that when I got redtop installed, they left the old KA plug where the signal cable should come from, and then they put a flat little piece of metal hooked up onto a speaker cable inside the KA signal plug and tapped it all around and the other end of that speaker cable onto the starter.
pretty much its wasnt doing a good contact & all which caused to fried my starter solinoid. Took it to Carims LLC here in Orlando and got that crap fixed.thanks Chris! you r the man! lol
terry_240sx
Car: '93 240sx hatch
the same thing happened to me, but it actually turned out to be my ignition module.
