car wont boost past 10 lbs
afmafia
whats up my car wont boost past 10lbs i dunno whats going on it drive fine untill 10 lbs then it like stutters . car was boosting fine untill 20 lbs what do u guys think may be the problem . any info is appreshated thanks jon
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
to answer we need more information
what upgrades do you have, how long were you boostin @ 20
stockwastegate/bov?
what boost controller
afmafia
tial 3[QUOTE=drifter_for_life06]to answer we need more information
stockwastegate/bov?
what boost controlltial 38mm wastegategt30r turbo ive been boosting 20lbs for a long timegreddy prfec b electronic boost
afmafia
greddy type rs bovgreddy intake manifold all the goodies =]
240TweakerNewbee
Car: 1989 Nissan 240SX
you have either spun a bearing, or you are running too rich... I was running too rich today and I had the same problem, I have it set at 12~13lbs, and I was lucky to see 8lbs, till I leaned out the A/F mix a bit... going to the dyno tomorrow to make sure its right.
Also, check for boost leaks
afmafia
its not a spun bearingif anything a boost leak well see tomm when i take all the boost lines apartit make be a vac line under the greddy intake for all i know
afmafia
checked for boost leaks or bad vac lines doesnt look like it, im going to check my spark plugs cause i may have gotton some bad gas. i already changed my fuel filter yesterday . any more info is welcomed .
drifter_for_life06
Car: Daily: '16 WRX
Exocet
afr is off i would assume
and ive heard the profec series boost controllers a crap and cant hold a concistent reading for crap
afmafia
i think i solve the problem i guess my battery died a few days ago so my boost controller resetits a greddy profec b the new one . so i guess i was over boosting . what do u guys think???????????
180fan
Car: 89 fastback
The profecs hold their boost more consistantly with a smoother ramp up than others.
Bad ebc settings can do a number of things so yeah I'd first try that instead of other things. post back with your results.
afmafia
looks like in high setting was =reset to 85 percent i lowered it to 60 percent and car drives fine . is this normal for the boostcontroller setting to go blank when the battery dies ?? isnt there a memory in it??
