Car won't turn over!
patdow1
I recently obtained a 90 300ZX TT which needed a Radiator, Alternator and Battery according to the previous owner. I purchased a re-manufactured alternator and a new battery as well as a new radiator. Everything was installed and I started it up when all of a sudden I heard a thudding noise so I shut it down, to realized that I forgot to tighten down the fan clutch bolts. Tightened everything down and tried to start it up with no luck!I spent the whole day trying to source the problem checking and rechecking all my steps. I ended up removing the cheap alarm that was installed thinking that this was the most likely problem. When removing the alarm brain I noticed that one of the fuses was blown so I continued removing it thinking this would remedy the problem. Alarm is completely out and car still wont' start. Everything turns on fuel pump primes but car will not turn over for nothing!
I need some suggestions because this car is wearing on me. I have two main fuses on the way since I read that this might be a potential culprit.
Zwicked
Car: 1990 300 ZX tt, 1990 240SX
When you turn the key, does the engine crank and just not start or it won't even crank over?
If it cranks but won't fire, check the wiring at the front if the engine behind the fan. If the fan was loose and wobbling, it could have damaged the PTU/CAS wiring and in that case it won't fire up.
patdow1
When I turn the key absolutely nothing, it doesn't even turn over or make any type of noise besides the fuel pump priming.
I checked all wiring that the fan blade could of came into contact with and not a scratch or wire out of place.
patdow1
Ok ran some codes with the help of the link that was provided by Zwicked Came up with two codes#12 Air Flow Meter Circuit#51 Injector Circuit
Where do I locate these circuits
Found this by using the SEARCHhttp://zclub.nicoclub.com/zerothread?id=289298The only problem is that my car will not run so how do I test? I checked all the connections and none of them have corrosion but a few do have cracked clips. Is there anywhere where I can purchase new ones to ensure this isn't the problem?
z32partsmo
Car: 1990 z32 NA 2 seater
before you get too deep make sure your battery casbles are tight with batt terminals I know you said you just replaced it but if they are loose this would be your problem.
es.biggs
Car: 1990 300ZX 5sp NA
z32partsmo wrote:before you get too deep make sure your battery casbles are tight with batt terminals I know you said you just replaced it but if they are loose this would be your problem.
Good call, I think that has happened to everybody on here at least once
patdow1
I've checked and re-checked the battery connections and I don't believe this is the culprit for my non starting issues, I wish it was that simple.
Would the idiot lights display on the dash if the battery connections were not making proper contact?
patdow1
I just installed a brand new starter as well as a Ignition Relay Switch (DS Fenderwell) and car still won't start. I'm starting to think the alarm closed the ignition switch (Under Hood). I"m gonna have to wait till Monday to order a new one.
vikesfankevin86
Car: 95 Nissan 300ZX TT
Hey I will keep an eye on this thead because my call will at times do the same thing. It is not the battery, I know that for sure. I just keep turning the key. After 5 or 6 times it will start up. It is very random when it does this but it has never just not started for a period of time. So maybe give that a try. Just keep turning the key.
vikesfankevin86
Oh and by the way my car did have an alarm system when I got it but did not/does not work.
patdow1
Today I cleaned just about every connection with a small file set and CRC QD-Electronic Cleaner to eliminate the possibility of corrosion being the culprit. I even relocated my PTU. I'm really starting to think it is a hidden immobilizer. I have a mobile installer coming out tomorrow morning to install a Up to date alarm I hope he can get me up and running tomorrow so that I can enjoy the fruits of my labor.
desbugg
Car: 93 Nissan 300zx Non Turbo
Mine is doing that now and I have tried all the things and have done all the things you've done lol... what was your problem?
GerryO
Car: 1993 J30t
Pearl White
Black Interior
There's a hidden connector on the side of the battery that I once forgot to connect. Is there power to the starter and all other electrical accessories?
Tried pulling all six spark plugs to see how the engine turns over by hand or if it cranks with them all removed? Any strong fuel odor, signs of fuel in the plenum or hydro-static locking?
90desilvia
Car: 90 nissan 240sx
I have a problem with my z32 with no start after changing out some bad injectors. I cant seem to find the problem. mine will crank but still nothing Im almost certain its getting gas I have a obd1 diagnostic reader hooks up to my computer says everythings fine but pulls an error code 21 ignition circuit
90desilvia
ok so I forgot to mention I blew one of my coil packs replaced it and just blew it again same one I just replaced faulty wiring is my best guess. any advice
inyrmouth
Car: 1991 nissan 300zx non turbo
90desilvia wrote:I have a problem with my z32 with no start after changing out some bad injectors. I cant seem to find the problem. mine will crank but still nothing Im almost certain its getting gas I have a obd1 diagnostic reader hooks up to my computer says everythings fine but pulls an error code 21 ignition circuit
yea does any one on here no anything bout 91 300zx cars or what!! Car cranks but wont start. ecu says error code 21 ingnition.
also # 3 coil pack is getting really hot and its jizzing black stuff out of it. What the hell is the problem i already put a new ptu. in it. Also when first got car the main fuse by the battery in the fusible link case next to battery there are like 5 fuses in there. I had to change to main fuse twice cuz it kept blowing. The main fuse to operate all electronic not sure what its called. since replaced no problem with that. Someone said something bout ground wire ok not a mechanic so i found 3. the two by 6 that connect together and the one jus to the left of that by # 5 injector. where the hell are the rest of them. I say a pic of the other two grounds but my car does not have them. Are they the same as the other 3 that i listed same color and looks i mean??????????? I saw one pic that one ground should be by the other fuse box in engine driver side attached to a bolt Thats not there??? Any body help with this ready to get rid of this car nothing but problem after problem and no one seems to know s***. I have replaced ptu, all 6 injectors , alternator, tps , battery fusible link the main one next to battery all 6 coil packs. and still getting 21 error code car will not start jus cranks. I could use a little help dont want to sell but kinda out of answers have had car for a year and has never drove correct lot of money in as well not sure what to do anymore pls help
inyrmouth
what up peeps I have had this 1991 300zx non turbo for bout 1 year. Lots problems I have replaced all 6 injectors all 6 coil packs ptu, tps and battery and the fusible link fuse by battery the main fuse twice. Now after putting car back together after new injectors i am gettin the car to crank but no start. error code 21 is comming up but i already replaced it las year so not sure why that code is back again. I even put the old one back on and still same problem. Also i was messing with the wires on the cam angle sensor while battery was hooked up and my # 3 Coil pack started sizzling and getting very hot with this black stringy stuff started to come out of coil pack, not all coil pack jus #3. What is that about????? so really not sure what else to do. Pls HELP ME GET THIS CAR RUNNING. All light work fuel pump is turning onn, and smell gas so not sure this sucks. Also I have the ground wire from injectors fuel rail hooked up. And the two (double) ground wires hooked up by #6 injector and by #5 injector the single ground hooked up. I can not find any other grounds any where. I have seen pics of where they should be but unless there diff ground wires from the other 3 i mentioned. Do they look diff from them diff color or what??????
