car won't start
babysirt
Car: 1991 240SX SE
When I try to crank the engine, it sounds like that rattling sounds that an impact gun makes as it is loosening a bolt. Like a rat-tat-tat sound.
I thought it was the starter. I bought a new one and got the same results. I took a closer look at the flywheel and noticed that the teeth were worn so I replaced the flywheel. I tried to start the car and got the same result.
impact240sx
Car: 1993 240sx Sr20det Gt2871R 2003 350z 1991 240sx Sr20det 2004 Land Rover DISCO
Blown motor? You might of thrown a rod and it didn't make it out of the block. Thats what my sentra sounded like after it blew up.
babysirt
Car: 1991 240SX SE
Its not blown. I can pop the clutch and drive off.
impact240sx
Then why didn't you say that to begin with? People can only help you if you help them by explaining your problem in detail, so technically the car will start it just wont start with the starter.
babysirt
Car: 1991 240SX SE
Order of events:-Car won't start with starter...makes rattling noise. I hop out and tap on the starter a couple times. Same noise. I engage the starter again a hold it for like 5 seconds and the car starts-Was able to drive car for 10 days straight-On day 11, try to start car....same rattling noise-Replaced starter...same problem-Brought start back and bought flywheel (teeth worn on the engine side). Replaced flywheel...same problem
My first thought is that now that the flywheel is good, the teeth on the starter are too worn. But I think it might be something else.
babysirt
Car: 1991 240SX SE
ttt
24j0hn
Car: 91' 240sx with some babying to be given
try a compression test to see whats up with the cylinders
babysirt
Car: 1991 240SX SE
The engine doesn't turn over. The only thing that happens when I try to start the engine is the loud rattling noise.
babysirt
Car: 1991 240SX SE
Here are pictures of the old starter and old flywheel. Would this kind of wear on both cuz their teeth not to engage?
Right now, I have that starter and a new flywheel.
babysirt
Car: 1991 240SX SE
It ended up being a bad battery! I guess it had enough juice to get the gear moving and making some contact but not enough juice to fully push the gear out to fully engage the flywheel teeth.
BearTrap
Car: '90 Hatch Bored, Ported, and Cammed
Hey, that looks like my starter and flywheel!!!
driftspec5
Car: nissan 240sx se
battery mine does that when its almost dead
