Car won't start
Chuby
Yesterday I cahnged out the high pressure line on my G50 and started the car up to check to make sure I had no leaks. I let it run for a few min. and shut it off. Come out this morning and turn the key and it just goes click. I changed out the starter when I got home and jumped off the starter relay and still nothing. It almost seems like the stater isn't getting any juice like it is engageing but not trying to turn. What else can I check or replace to see if it is shot? Or what is wrong with my car?
superuber
WOW! First off, what pressure line are you talking about? Also check your battery voltage to see how much juice is in it. Could be as simple as that.If you have 12.7 volts at the battery check your voltage at your starter then. We really need more info. Am I correct to say you did change your starter? What year? Mileage? Service history? I have seen low voltage in batteries do this but with little info it could be anything.MORE INFO=
Chuby
Oh lord, nevermind.The P/S line was the one coming out of the pump with the 24mm headed banjo bolts.
superuber
Chuby wrote:Oh lord, nevermind.
Chuby
superuber wrote:
I am a moron
superuber
Join the club! Atleast you can admit it.
