fun240 »
https://forums.nicoclub.com/fun240-u58771.html
Thu Jan 22, 2009 2:39 pm
Ok i'm getting all dashboard lights and when i turn to key to full start position, it clicks
Car is manual - There's not enough room to pop it in the parking lot, at the bottom of a hill
96' motor - i've vacuum locked the motor one time in 96' chassis in the exact same spot that the fuel gauge is in now, but in the 96' chassis
We replaced the starter
I've had this problem for a long time now. After the swap everything was fine until i started actually driving it. I put a amp wire on my positive terminal, to play a system
The car should be turning over.
The car did not die or sputter. It just won't crank after i parked it.
Fuses are good, battery is good.
A couple of things i'm thinking
The ignition(where i put the key in, someone fill in please) maybe bad, but the car should be turning over?
The clicky thing at the bottom of my clutch pedal is broke and making the starter not engage.
The starter is not engaging at all. And has been doing this for awhile, after i add my system...
Anyone have some insite? Maybe i vapor locked it, lol
