Pull the codes first like Yoda said but it sounds like you might have a spark problem because of the gas on the plug?petar_83 wrote:it's 93.Could it be bad injector or something?When I pulled the coils out one of them was oil and gas all over the other ones were fine. One more thing one of the spark-plugs on other cylinder was black.
You said nothing as in no starter after you pulled the code -- did you put the ECU back into the normal position?petar_83 wrote:I tried that and it won't even try to start.No sign to start at all.Nothing.And why would the ECU say that everything is fine if there is something wrong shouldn't it say different code or someting.It's just that 55.I'm stuck.Help!!!
When you say won't start, you mean the engine isn't even turning over?petar_83 wrote:So if the battery is bad even if you jump it from another car it may not start??? Is that possible?well the battery still had some power in there.
