Acecool »
https://forums.nicoclub.com/acecool-u46759.html
Mon Sep 11, 2006 4:15 pm
I had close to the same problem..
What I did was checked the spark plugs (burnt badly, but still good, still replaced them)
Took the plugs off of the injectors (There is a staple type thing holding it down, pry it off with a flat screwdriver, then use needlenose to make sure it doesnt fall DO NOT FORCE IT)
Clean the corrosion off the plugs (Disconnect battery, it is safer, but probably not required..)Sprayed stuff from radio shack into each plug and got the gunk off..
Then I got it to crank every now and again, by pumping the gas pedal it would start for a few seconds then I could stabalize the rev at 1500RPM (wouldnt go above 2500) with a cane.. :-)
Anyway while it was started I unplugged each of the wires, one by one (replace it after you take it off) and noticed with each one the engine would stutter showing me that the injectors and plugs were working..
After being stuck at this part for several hours I did a search for REV and 2500 and found it could be the ECS or the MAF (Mass AirFlow sensor)
On my car, the plug is ontop of the Airfilter thing in a silver thing.. Engine was off, I fiddled with that, and it cranked right up
Not sure if this will help, but it might.. Check the easy stuff, and do you have a FSM?
