Hey i have a wierd problem. I just put in a SR20DET in my fastback. The very first time the car started, but had a really bad idle or almost a misfire. I think i had a short the EGI pump relay was turning on and off. I think this was the problem of the wonky start. So checked the wires everything looks good. Had one wire touching another, but took care of that(I'll get pics up soon). Now i'm at a point that the fuel pump does not prime up when key is turned. The car will crank, but i think the fuel is not working at all. I've searched the only that i have found so far is that i should try the voltage and see if there is any at all. (Just to mention that the fuel pump use to prime up.) Now nothing. I don't know what i did wrong. I followed the wiring diagram from
http://www.srswap.com. I'm really stuck can someone help me out. I want my car to start.
Thanks,Newbie.
P.S. If this is in the wrong section please could you move it to the proper one. Thanks.
