Car won't start HELP!!!!
MAXIMELTMAN
4th Gen 1999 Maxima SE. Just changed clutch and installed Quaife ATB Differential. Was on jackstands for about a month or so. Now it's back on her feet and when I start her up, it takes quite a bit of cranking before she gets running. Is the fuel bad? She starts up after a few attempts, and this was never a problem before...I even put a few gallons of fresh fuel in and no better. Some guys are tyalking about sanding the bellhousing/starter surfaces, or the starter problem might surface...any insight?
D_roc
Car: 2001 Maxima 20th aniv edition
could be a couple of reasons, i'd first check the spark plugs and the starter. how's the battery?
lock0002
Car: 1997 Nissan Maxima GXE
Maybe the crank shaft sensor on the transmission. I did a clutch job and i forgot to plug that in and all it did was turn over. I think mine is bad as we speak. it takes a good 5 to 10 cranks sometimes to start. i just havent had the money to go replace yet
kzoosho
Car: Turboed 1997 Nissan Maxima SE
Thats one of the biggest issues with 4th gens man. If you dont sand that surface it causes alot of issues. Its a ground and if its not grounding then you will have more resistance for other items as well.
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
I would check the timing too
Check camshaft and crankshaft position sensors
Check for basics, fuel, spark, air
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Check your battery connectors. The battery may be good but corrosion on the connectors will reduce the 'juice' going to your starter. It's also possible that you have a 'sticky' starter. It's not difficult to remove. Disassemble the starter and put lithium grease on the gears. You can also check the integrity of the connection to the starter solenoid.
Rod
