Hey guys,
The Z has had some trouble starting recently. I woke up one day to go to work and turned the key and tried starting the car and it would crank but no start. Tried again and it started and stayed on for a bit then it shut off. My co worker told me it may be a clogged fuel filter. Went to replace the fuel filter and it started up right away. I let the car sit there letting the fuel go through the new filter. It worked the whole next day, took me to work and did errands and started fine until I was starting to leave to go home. I started the Z and started driving off then while slowing down to a stop, the car shuts off. Tried turning it on again and same problem cranks but no start. A couple min later it started again and took me home completely fine. Woke up the next day to check on it if it was ok and now the Z won't start. Don't know what else may be the problem. I replaced the fuel filter right I think? Took off the fuel pump fuse and turned the car on to de-pressurize the line and then repalced the filter and put the fuse back on and started it and let it sit for 10min and it was fine.
