masterbunta »
https://forums.nicoclub.com/masterbunta-u78563.html
Tue Oct 16, 2007 4:39 am
I fits cranking too slow, you can flood the engine with gas and foul out the sparkplugs. The engine is not spinning fast enough to actually start, but fuel is being sprayed into the engine at the same rate it would if the engine was turning full speed.
If you have a great battery and the starter is still turning slow, maybe the starter, or a weak ground, or connections at the battery.
With a good charge, there should be no reason your starter should turn slowly.
