car won't start after swap
240droptop
Car: 93 240sx Convertable
k we just finished my 5 speed swap on my car yah
OK so here is the problem I go to start my car for the first time in about 2 months this is just after I put a brand new battery in. k so I go to start it and it dosent start ok what the heck so I hook my battery booster up and give it some extra juice still the car dosent start I call my budy I take the starter off and he turns the key and the starter spins and comes out so thats fine. I put it back in try agains still nothing the fleewheel is turning and the car is turning over but stll she dosent start so I look towards fuel the pump is working and the motor is definitly getting fuel ok what now its getting air so I check my fueses alll good. Ok starting to get annoied so next we look towards ignition we pull out a spark plug and test to see if it sparks and it dosent ok so we replace the ingition coil and go to start hmm still no spark we change the wires and still no spark. What could be wroung its not getting a spark what needs to be done this poblem is on my 240sx convertible 5 speed let me know thxs
SlidnSideways
Car: 97 Nissan 240sx SE
Did you test spark at the tip of the spark plug or where the plug wire hooks onto the spark plug? If you tested at spark plug try unhooking the plug wire and holding needle nose (with rubber handles) close to the plug wire...the spark should bridge the gap between the needlenose and the wire.
If you see a spark its most likely either bad plugs or wrong gap.
If no spark seen from testing the plug wire, it could be distributor cap and/or rotor.
Check those out and post your finding.
--Tim--
TwinCam77
Car: 91 240
k this problem is simple for every swap that anyone does. with an automatic transmission notice how the car wont start if it isnt in neutral or in park, thats because of the neutral saftey switch thats in every car. if you take the auto transmission out there isnt a neutral so therefor your car wont start.... so what you need to do is cut the wire on the starter and wire it to a push button and wire the push button to the positive side of the battery. k then push the key in the on posistion then push the button and volia your car is now running......... let me know your results
240droptop
TwinCam77 wrote:k this problem is simple for every swap that anyone does. with an automatic transmission notice how the car wont start if it isnt in neutral or in park, thats because of the neutral saftey switch thats in every car. if you take the auto transmission out there isnt a neutral so therefor your car wont start.... so what you need to do is cut the wire on the starter and wire it to a push button and wire the push button to the positive side of the battery. k then push the key in the on posistion then push the button and volia your car is now running......... let me know your results
you don't need to fab a button theres two wires comeing off of your passenger fuse box you have to splice those together to amke the car think its in park if you don;t the car won't even turn over i'm gunan check my grounds and trace back the wires and try gettign a spark again i'll kep you guys posted
