skwertle »
https://forums.nicoclub.com/skwertle-u186.html
Tue Jan 20, 2004 9:34 am
Ok i replaced my upper chain tensioner and now for some reason my car will not start.
the motor turns, i get gas and spark, but the engine will not start.
when i initially took of the tensioner and put in a new one. i forgot to turn the crankbolt to TDC on piston one, nor did i line up the distributor correctly. And tried to start the engine. It didn't start cuz timing was really off.
so I took off the distributor and set the engine to TDC on piston one, put the distributor in the correct way and it still won't start.
So, now i took off the front cover (just the upper part) to get a good look at my upper chain to see if it skip teeth but the markings on the chain are gone. i see 2 darker links and one brighter link on the chain. are thoughs the marks? if so they are still in the correct spot.
the only thing i can see out of place is that at TDC the camshaft marking on one of the cams isn't orientated the exact same direction as the picture in the FSM. but if the chain is aligned correctly how can it be off?
does anybody have any idea what's goin on? does anybody know the number of links between the 2 camshaft markings and idler sprocket?
help
