vancouverbc wrote:zerothread/357530
are you on the right tooth? is the distribuotor bolt in the middle or to one side. does moving distributor help idle.
right tooth? What do you mean?
As for the distributor bolt, the 2 that hold it on to the engine? I made a mark with a sharpie before I took it off and repositioned them where they were when I put it back.
I made sure the #1 cam lobes were pointing outwards and the distributor cap was pointing at the #1 spark plug before I removed anything.
When it was put back, the problem started. I've changed the whole distributor before without any issues.
Oh well, another day. Let's go take a look at it.
Pray for me/wish me luck.
EDIT: Oh, btw If I retard the timing by rotating the distributor counterclockwise, the car sounds worse. Advancing it beyond the original sharpie mark....don't remember what that does. I'll try that in a bit.
Modified by MAXIMUS Nismo at 7:51 AM 4/7/2009
Modified by MAXIMUS Nismo at 7:52 AM 4/7/2009
