Car won't start after hitting bumps. ehhh?
beatd
Car: 92 KA-T 240SX and 08 Fit Sport
Hey guys its me again. s13 with a t25 setup. Last night while i was driving i crossed an intersection and the road on the other side was extremely bumpy going about 30 mph. btw i'm running on megan streets on the softest level. anyway while crossing the bumpy section my car just decided to die so i had to roll to a stop. After stopping i tried to start it back up but all it would do was crank and not fire up. heres a list of things i've already checked:-battery-plugs where not wet-fuel pump is priming-intercooler piping is all connected and good-MAF is plugged and good (blow through setup)-sparkplug wires all connected and coil wire good-dizzy cap and rotor good-no leaks
lastly-i used a test light for the drive side foot panel fuses and all of them lit up except the fuse on slot 12 - "10 amp" fuse(second to the last on the right side labeled "st signal")
my question is what is the fuse for and could that be why my car won't fire up?
480sx
Car: 1996 Pearl White 240sx
Well replace that fuse and find out. If your plugs wernt wet then your engines prly not getting fuel. Run the self diagnostic on your ECU and let us know whats up.
beatd
i changed the fuse last night and tried to start it again but it didn't work. I'll checck the self diagnostic today and see whats up
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
Well you if you bottomed out that bad, check underneath the car and see what got hit, and trace it to what could gotten knocked loose?
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
GTR PrYdE wrote:Well you if you bottomed out that bad, check underneath the car and see what got hit, and trace it to what could gotten knocked loose?
+1 LOL, that would be funny if he havent check and something was damage under the engine.
beatd
lol that would have been funny, but unfortunately that was the first thing i checked and nothing was wrong. i knew i didn't bottom out. However i did find out the problem and one of the coil harness was half way off and the other one was completely off, so when i plugged both back in it started right up. Thanks!
