anlasak wrote:Did you have the crank pulley set at (b)tdc?
Was the #1 piston almost at the top of its stroke?
Were the cam lobes for cylinder #1 opposing when you set the timing?
Was your rotor set at the #1 position after installing your distributor?
Are all your injectors connected?
Did you replace the fuse for the fuel pump?(Assuming you pulled it and cranked her a couple times to relieve the fuel line pressure)
Did you re-connect all the ground wires?
yes to everything, i put an injector on a test light and it was firing. also, the plugs get wet after a while so i know there is fuel.
i didn't disconnect any grounds.... i left the intake mani in the car when i pulled the head.
I know it is at tdc for number one because i put a screwdriver down the plug hole and i then turn the motor to the second to the left timing mark on the crank when the screwdriver is up.
I have also pulled the cover to check the upper chain and that is right and the cams were pointing opposite.
could the lower chain have moved a tooth by just sitting there with the front cover on? i didn't think it could which is why i didn't tie it to something
