Car won't start after code reader
alphacode
Car: 1995 240SX
I just picked up my 2nd 95 240sx se, its a manual. I bought it and started to drive it back across Florida, stopped at a nearby advanced auto parts on the trip back, got the code read for bank one sensor and a knock sensor got the error cleared.. and then the car would not start
there is no Clicks..all lights on the dash work..car will not turn over.I ended up push starting it with some help from the advance staff, after we got the car started it ran just the same. But i still can't get it to turn over.
Also the car has a Prolock system in it that was wired up in an ignition switch line.. i cut everything out and ran all the stock wires back in place, everything appears to make good connection one wire (black with yellow stripe) was cut in half and routed threw the system all the others seem to just be spliced into.
Modified by alphacode at 8:00 AM 10/25/2009
alphacode
Car: 1995 240SX
Took the starter to my parts store it ended up bad, I guess it was just verry weird timing that the started would go bad, or hit it's deadspot at the parts store..
