maxnix wrote:1.) Yes, that would put a drain on the battery to the extent any bulbs were burning, and shorter bulb life. Wonder why you left the door open?
2.) What is "it"? What cap on which door and why? Please explain.
I left the rear car doors open for 2-3hours between working."It" is the fuel filler lid. I left it slightly ajar for a few days.
GQ Jay wrote:if you can hear the pump hummm, then you probably did get red/black correct. provided it does actually crank and not fire, my guess is you are out of gas.
That might be the case I was thinking that also. It does crank and not fire.
Q451990 wrote:The pump is a DC motor... I suspect it would just spin backwards you reversed the polarity. I assume you put the fuel pump fuse back in, and then confirmed that it's still OK?
Heath
Yes I put the fuel cap back on then I put the fuel pump fuse back in. How can you tell if it is spinning backwards? I used common sense and whatever memory I had to say to myself that the black wire is mounted further away than the red wire so it should go to one side and not the other.
I'm still trying to take in any possible options of what it may be before I call a tow truck to get gas just in case that does not work.
