Car won't start after build?!
alpalwal
I dropped my ka-t in my 240 and I'm trying to get it to start. the motor is built and right now is being tuned by a safc 2
I have spark at the coil and at at least plug number 1
injectors are shooting fuel. I think I have them in the right order. how can I make sure?
every once in a while it'll ignite once... just a *pop* of it firing. but no more than one in a row.
anything else to check? I want to get this ***** running
nb07bcar
move the dizzy one tooth front or back. thats might work
GEO
Car: 95 240sx KA-T
lol at the "coil"
j-z
Car: 95 240sx
did you change the injectors out? if so, you could def have one/some of them leaking as that would cause the symptoms your having. an easy way to check this is to unbolt the rail from the intake mani with the fuel lines still connected. pull the assembly out to where you can see the tips of the injectors. turn the key into the on position so that the fuel pump kicks on and make sure you have no fuel leaking. if you do then youve got to replace the orings and lube them up with motor oil before installing.
alpalwal
nb07bcar wrote:move the dizzy one tooth front or back. thats might work
off one tooth ftw
thanks guys
