NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Wed Apr 06, 2005 4:12 pm
Matt is right. If they charge you to pull the transmission and when they get it out they see the clutch is blown out they are just gonna charge you for the removing the trans and reinstaling it. Which was what they did. In other words the estimate they give you should include the time to remove the trans and look at the clutch and to reinstall it to its state it was when you brought it to them. Ask to be sure the price they quote you is to R&R the trans. If so they should not be charging you any additional except the clutch kit. Now on the other end of things, If they get the trans out and find the clutch is ok, then they will need to tear down the trans and inspect it. so that would be additional time.
