Mike94ZLT1 »
https://forums.nicoclub.com/mike94zlt1-u278973.html
Thu Oct 29, 2020 1:43 pm
Hey guys, I need some help. Two months ago I hopped in my car, and it wouldn't shift out of park. I had to pop that little tab by the shifter and use a zip tie to depress the lockout, so I could go. Later that day my car also decided it didn't want to turn off. I could turn the key to the off position, take the key out, and it would still run. The only way I could get it to turn off was to push the remote start button on my key fob (aftermarket). I ended up pulling the console and physically blocking the shift lock so I could shift the car without a zip tie, so that works. But it still did the thing where I need to use the fob to turn it off. I was reading and I think the two issues may be related, like a fuse or relay or something. The fuses under the hood by the battery all look fine, is there another fuse panel elsewhere? I don't drive this thing much anymore, it mainly is used as a winter warrior. I would like to fix the issue before the weather turns too bad. Thanks! -Mike
