Two-Fortee »
https://forums.nicoclub.com/two-fortee-u80523.html
Thu Jun 04, 2009 7:00 am
If I leave my car for a day or so, go to start it, everything is fine. Idles great, then after about 2 minutes on idle it craps out. Then it won't start. Will keep turning over but wont fire up.
If I leave it for 10 minutes or so, and try and start it, it still won't. It will just keep turning over but almost seems like its out of gas or has no spark. Sometimes if I leave it for a little, like 30 minutes, it will start, barely, but very quickly bog right out.
Seems like as soon as the engine is just a little bit warm the car won't run at all.
ECU reads 55 (no codes), everything is hooked up properly, by the looks of it. Compression is 150 all accross. Battery is good.
Its such a weird problem, can anyone figure this out?
Thanks
