Car won't idle...
StuntingShaggy
Car: 1991 240sx
Ok folks I solved the water in the oil problem, but my car still won't idle. There's only two possibilities left. The first is that the numerous disconnected vacuum lines won't let it idle. The second is that it's mistimed. Which one is it guys? I'm tending to think that it has to be the vacuum lines. I mean, a mistimed distributor will still let it idle won't it?
mrzabala
Car: 93 Nissan 240SX SE Hatch
Always check the most obvious first, which in this case vacuum lines. Fsm has the vacuum diagram. But to be kind of vague, check the one on the brake booster, valve cover, canister, and intake pipe.
180fan
Car: 89 fastback
sometimes you'll forget stuff when putting it all back together.
StuntingShaggy
Car: 1991 240sx
Yeah that's exactly what happened, I paid no attention when I switched blocks and didn't know what went where. bleh.
