Car won't idle, please help.
Red Lightning
Hi, my friend has a 95 Altima,it will start and run for a few seconds, then it dies. My friend took it to a mechanic, and the mechanic told her the distributor is bad, and it costs $700 to replace it. Is this too much? I can't imagine it to be that expensive. Does KA's have bad coil packs like SR's? If not, is the distributor cap and rotor hard to replace? If not I'll just change it for her. Also, could this be the fuel pump? Is there a way to test the pump? Thanks in advance. :help :ylsuper
240drift
if you want to check the fuel pump... turn the car on not running just on... and listen for a noise that will stop after like 3 or 4 seconds... that will be the fuel pump priming itself... or you can go to the fuel rail and hook up a fuel pressure tester to the shrader valve and that will tell you if you have enough fuel pressure...
good luck
94HBsr20
i need to sell a stock ka24de if interested my aol screen name is trappedxxinside
