TheKryptKeeper »
https://forums.nicoclub.com/thekryptkeeper-u55651.html
Fri Jan 16, 2009 9:34 am
Hey guys, thanks in advance for your help with this.
93 240sx ka24de
The story is, I bought the car, beat it up a bit, lost a bunch of water on the freeway, and blew a head gasket. I removed the head, resurfaced it, replaced the head gasket, and it didn't run. Everyone said that i bent the valves. So I bought a new head, and gasket, and did it again, this time very carefully. I got it correct, and spent several weeks trying to time it correctly. The best that i have gotten is that it starts and runs, but no idle, or full power, only like 60% power.
That tells me the timing is off, but it seems to be either too far one way or the other when i change it. The idle screw does nothing, and the dizzy advance/retard only make it worse from where it is. I never did check the bottom chain to see if it was on right cause i figure that as long as it is at tdc, then it works, then i learned i could be half a tooth off, so i rotated it around, and that is how i got to where i am.
The leakdown is good, so the valves are good. I drove it to the tire store and back with little problem. Am I just going about it wrong, or can it be something else? people have said its the IACV, but I already removed and replaced that before the head gasket.
Thanks again, Krypt
